You are here: PSPad forum > English discussion forum > Preserve Bookmarks
Posted by: idefix2 | Date: 2020-12-20 22:53 | IP: IP Logged
Is it possible with PSPad to preserve bookmarks for a file from one edit session to the next?
This would be VERY helpful.
Posted by: pspad | Date: 2020-12-21 04:12 | IP: IP Logged
Enable save file state in the progeam settings
Bokmarks are stored in the project file too
Posted by: idefix2 | Date: 2020-12-21 19:46 | IP: IP Logged
Thank you.
pspad is really a great software
Posted by: idefix2 | Date: 2020-12-22 21:33 | IP: IP Logged
Now another question in this context: Would it be possible to make bookmark setting an "undoable action".
It happens to me that instead of ctrl-number, by mistake I click ctrl-shift-number, which moves the bookmark to the cursor position, instead of moving the cursor to the bookmark position. It would be great if in such a situation, I could undo the mistake and easily restore the old bookmark position using ctrl-z
Edited 1 time(s). Last edit at 2020-12-22 21:34 by idefix2.
