You are here: PSPad forum > English discussion forum > Re: More visible the vertical line
#1 More visible the vertical line
Posted by: Esgrimidor | Date: 2020-12-12 18:09 | IP: IP Logged
How can change the thickness or color ?
Best Regards
Nice program indeed
#2 Re: More visible the vertical line
Posted by: pspad | Date: 2020-12-12 18:15 | IP: IP Logged
There isn't possibility to set thickness, cause with thick line it will cover text. But you can set color in the program settings / Colors - Right edge.
If you set color to red, line will be more visible
#3 Re: More visible the vertical line
Posted by: Esgrimidor | Date: 2020-12-12 22:16 | IP: IP Logged
Understood.
That's enough
Best Regards
Nice program indeed
