You are here: PSPad forum > English discussion forum > Line suddenly changes to white on white
Posted by: dapspuser | Date: 2020-10-24 13:23 | IP: IP Logged
When entering the following code a Python-File
x = """
abc"
and then escaping the double quote at the end of line #2 with a backslash as follows, then the line changes to white on white and is not visible anymore.
x = """
abc\"
This cannot be changed in the highlighter.
Posted by: pspad | Date: 2020-10-24 13:51 | IP: IP Logged
There is problem in Python highlighter - some rule caused this wrong painting. I will fix it
Posted by: pspad | Date: 2020-10-24 14:22 | IP: IP Logged
Problem found. Fix will be available in the next build
