You are here: PSPad forum > English discussion forum > encoding dialog
encoding dialog
#1 encoding dialog
Posted by: froschi | Date: 2020-10-23 12:56 | IP: IP Logged
pls check these buttons
i.imgur.com
#2 Re: encoding dialog
Posted by: froschi | Date: 2020-10-23 12:57 | IP: IP Logged
how can i change the standard encoding for files to utf-8?
#3 Re: encoding dialog
Posted by: pspad | Date: 2020-10-23 13:23 | IP: IP Logged
froschi:
Click on the encoding menu, select encoding you want and save file.
As alternative you can click/dblclick on the encoding on the toolbar
If you have bigger amount of files, you can use batch change encoding dialog.
Changed files are from safety reason stored on different folder, it has no influence of original files. When you check all is OK, you can replace original files.
Edited 1 time(s). Last edit at 2020-10-23 13:25 by pspad.
#4 Re: encoding dialog
Posted by: froschi | Date: 2020-10-23 13:38 | IP: IP Logged
how can i change the default encoding for new files?
especally when i create them at ftp.
#5 Re: encoding dialog
Posted by: pspad | Date: 2020-10-23 15:50 | IP: IP Logged
Program settings / File and dirs
There is default settings for new file
#6 Re: encoding dialog
Posted by: froschi | Date: 2020-10-23 16:39 | IP: IP Logged
found! perfect. thank you.
