You are here: PSPad forum > English discussion forum > Use tab character
Posted by: idefix2 | Date: 2020-10-01 14:33 | IP: IP Logged
Is it possible to insert a tab character in a file when the tab key is pressed, instead of spaces?
Posted by: idefix2 | Date: 2020-10-01 14:47 | IP: IP Logged
I have tried to activate the feature through
Program settings - tab instead of spaces
but pspad still inserts spaces when I press tab.
Posted by: pspad | Date: 2020-10-01 17:23 | IP: IP Logged
In the program settings / Editor 2
check Real tabs, Smart tabs must be unchecked
This is a general settings
Spaces/Tabs is possible to set on the highlighter level for each highlighter in the menu settings / Highlighter settings / specification tab.
Checkbox there has 3 states - checked, unchecked / Greyed (accepts global settings)
Highlighter settings has higer priority than program settings
Posted by: idefix2 | Date: 2020-10-17 15:52 | IP: IP Logged
I am sorry, it does not seem to work. Here are my settings for ini-files. Still, PSPad inserts spaces when I press tab. According to your answer, the Highlighter settings should override the global settings.
Edited 1 time(s). Last edit at 2020-10-17 15:54 by idefix2.
Posted by: pspad | Date: 2020-10-17 16:07 | IP: IP Logged
Check setting / editor 2
Can you send me screenshot?
