You are here: PSPad forum > English discussion forum > Re: Project in project
Posted by: aiutopc | Date: 2020-09-07 10:57 | IP: IP Logged
Can I insert a project into another ?
I have a lot of old projetcs, and I want to create a project with all of them into.
A Main Project file in which I can import old projects, and open then with a click if I need,
AiutoPc
Posted by: pspad | Date: 2020-09-07 11:45 | IP: IP Logged
There is no such possibility now.
But it's a easy to do it by edititng project file.
If you look into project file, the structure of files is simple
Under [Project tree] section is tree of files and folders
level = real tab
first level is name of the project - mandatory
folder begins with "+" or "-" sign (expanded/collapsed)
You can simple open all PPR files (rename extension to TXT) or in PSPad go to Open - don't dblclick it to prevent open it as project.
Copy content of the [Project tree] section without the first level and copy it to end of [project tree section].
You can add folder for each project (increase level of one tab)
Posted by: aiutopc | Date: 2020-09-08 10:53 | IP: IP Logged
Thank you, I made just as you suggested
AiutoPc
