You are here: PSPad forum > English discussion forum > Control Z
Posted by: Esgrimidor | Date: 2020-09-06 14:04 | IP: IP Logged
I need today undo last change many times.
Is there a way to do this more confortable ? That is go back a number of keystrokes or something
Best Regards
Nice program indeed
Posted by: pspad | Date: 2020-09-06 14:10 | IP: IP Logged
Make a backup and use backup file instead of undo?
Or don't save file and reload it (ctrl+R) instead of undo?
Posted by: Esgrimidor | Date: 2020-09-06 14:29 | IP: IP Logged
thanks .
Is an ever changing file. And in short time.
I was thinking in a script to undone x times instead of once.
Is it possible ?
Note : how many times you can undone ? . is it configured in the configuration anyplace ?
Best Regards
Nice program indeed
Edited 1 time(s). Last edit at 2020-09-06 14:35 by Esgrimidor.
Posted by: pspad | Date: 2020-09-06 15:49 | IP: IP Logged
No problem to call undo from script - use editorCommand() function and call undo as many time as you need
Posted by: Esgrimidor | Date: 2020-09-06 17:44 | IP: IP Logged
pspad thanks a lot.
Going to try.
and of course the reverse option too if I go too far....
Note : please where is the command editor function ?. is in the macros ?
Nice program indeed
Edited 1 time(s). Last edit at 2020-09-06 17:47 by Esgrimidor.
Posted by: pspad | Date: 2020-09-06 18:27 | IP: IP Logged
File scripting.rtf in the pspad folder or pspad helo
Command ecUndo or ecRedo
Posted by: Esgrimidor | Date: 2020-09-07 10:43 | IP: IP Logged
I know you are right, but I don't have the necessary basis to do that.
In other words : I don't understand.
Note : Can you put screenshots, the option I must do . A step instruction ?
Best Regards
Nice program indeed
Edited 1 time(s). Last edit at 2020-09-07 10:48 by Esgrimidor.
Posted by: Esgrimidor | Date: 2020-09-07 10:59 | IP: IP Logged
I think I need a versioning software.
a plugin or a script for versioning with pspad.
Exist something for this ?
Nice program indeed
Posted by: pspad | Date: 2020-09-07 11:52 | IP: IP Logged
Esgrimidor:I think I need a versioning software.a plugin or a script for versioning with pspad.
What exactly are you awaiting from it? You need to have some shared place for versioning software (it can be local drive).
Standard work is:
you make local copy of published version, edit it and commit changes to versioning software. In the versioning software you can see list of changes, you can return to some version e.t.c.
There is no plugin for now, all can be handled by calling command version of versioning software. Each software has some specifics. Do you mean GitHub or something like this?
Posted by: pspad | Date: 2020-09-07 11:55 | IP: IP Logged
Esgrimidor:I know you are right, but I don't have the necessary basis to do that.In other words : I don't understand.
Best Regards
You can use Macro recorder in PSPad for it.
Simply way:
Ctrl+F5 (start recording)
Ctrl+Z
Ctrl+Z (e.g. 10 times)
Ctrl+F5 (stop recording)
Now you can call your recorder macro by F5 and it will call undo 10 times
