You are here: PSPad forum > English discussion forum > Re: Which files to back up for saving settings?
Posted by: rovf | Date: 2020-08-17 12:23 | IP: IP Logged
I have stored PsPad in a directory C:\port\pspad503en (i.e. this is where the pspad.exe resides). Which files do I have to back up, so that I can restore them if necessary, to get all my settings back (project definition, program settings, highlighter settings etc.)? I see plenty of INI-fiels in the subdirectories Colors and Syntax, and there is also a pspad.ini in the base directory, which has a recent date, but I wonder whether this list is complete?
Ronald Fischer (Germany)
Posted by: pspad | Date: 2020-08-17 13:23 | IP: IP Logged
Open program settings / Backup
There is a possibility to save / restore important config files into ZIP archive.
You can use PSPad as portable (unpack ZIP version into folder outside of Program files folder) and then all files are stored in PSPad folder. You can move it to any folder, take on the FlashDisk...
