You are here: PSPad forum > English discussion forum > Re: Truncated folder names
#1 Truncated folder names
Posted by: rvinea | Date: 2020-08-13 08:31 | IP: IP Logged
Hi all,
For some time now, the folder names in the Tools Panel/Project View appear truncated (i.e. 'addi...' instead of 'addins'. This happens only in the Project View and only for folders (not files).
Is this a bug/feature/option? Its a bit annoying...
#2 Re: Truncated folder names
Posted by: pspad | Date: 2020-08-13 10:50 | IP: IP Logged
Because there isn't enough śpace, names are shortened.
Send me screenshot please
#3 Re: Truncated folder names
Posted by: rvinea | Date: 2020-09-25 07:49 | IP: IP Logged
How do I send you a screenshot?
In any case, If I create a new project and add an existing file, it will just look like this
|| New Project
|| |_Fold...
|| |_Filename.txt
On the other hand, if I add a new file,
|| New Project
|| |_Fold...
|| |_New1.t...
As soon as I save the file...
|| New Project
|| |_Fold...
|| |_New1.txt
#4 Re: Truncated folder names
Posted by: pspad | Date: 2020-09-25 08:32 | IP: IP Logged
For screenshot use any file sharing service and put link here, e.g. ctrlv.cz
Regards to shortened file names. Shortened names are stored in project or do you see it only? When you put cursor on the name, do you see full file name?
You can increase width of the left panel if you need to see more chars in file name. PSpad will remember the size automatically for you.
#5 Re: Truncated folder names
Posted by: rvinea | Date: 2020-09-25 14:23 | IP: IP Logged
Hi
1) the project file (.ppr) contains the full names.
2) when the cursor is on the folder name, the popup shows the full name.
3) the left project panel width does not affect the folder name truncation.
#6 Re: Truncated folder names
Posted by: pspad | Date: 2020-09-27 08:07 | IP: IP Logged
Send me screenshot please, you can send it to support mail.
I tried to get project file names shortened, but I wasn't able to simulate it.
#7 Re: Truncated folder names
Posted by: rvinea | Date: 2020-11-25 07:47 | IP: IP Logged
The problem is gone with version 5.0.4 (535) though I see no evidence of a fix in the change log.
