You are here: PSPad forum > English discussion forum > Connecting to Dreamhost account
#1 Connecting to Dreamhost account
Posted by: keress | Date: 2020-07-28 18:49 | IP: IP Logged
I've got credentials working in Filezilla, so I'm sure I've got the right ones. I can't get them to work on PSPad, though. I had to use SFTP - SSH File Transfer Protocol on Filezilla, and I'm not sure what's comparable on PSPad. I think I've tried every checkbox, with nothing working. It gets to 'password' and it stops. Below is the log generated. What does '500 AUTH not understood' mean? Then it's saying the Login is incorrect, but the exact username and password work fine on Filezilla. Can anyone help?
SSL library: OpenSSL 1.0.2k 26 Jan 2017
Connecting to: cheroenhaka-nottoway.org
220 DreamHost FTP Server
AUTH TLS
USER teerheer
331 Password required for teerheer
PASS xxxxx
530 Login incorrect.
AUTH TLS
USER teerheer
PASS xxxxx
Certificate:
Can't connect
LastError: 0
#2 Re: Connecting to Dreamhost account
Posted by: pspad | Date: 2020-07-28 19:25 | IP: IP Logged
PSPad doesn't support SFTP, it supports FTPS only (SSL/TLS)
#3 Re: Connecting to Dreamhost account
Posted by: Andreas | Date: 2020-07-28 19:48 | IP: IP Logged
Try this:
Establish an SSH connection with Bitvise SSH Client www.bitvise.com
Go to the tab "Services". Check "FTP-to-SFTP Bridge" enabled.
Listen interface = 127.0.0.1
Listen port = 21 (not sure if you need this)
Now go to your connection within PSPad. Set the server to 127.0.0.1.
Now you should be able to connect PSPad via SFTP.
#4 Re: Connecting to Dreamhost account
Posted by: pspad | Date: 2020-07-29 04:42 | IP: IP Logged
Thank you for tip, I will add it into PSPad help
#5 Re: Connecting to Dreamhost account
Posted by: Andreas | Date: 2020-07-30 15:48 | IP: IP Logged
I think its already somewhere here in the forum grinning smiley
