You are here: PSPad forum > English discussion forum > Re: PsPad.ini modifications not as expected
#1 PsPad.ini modifications not as expected
Posted by: Extranjero | Date: 2020-07-08 21:58 | IP: IP Logged
Modifying the PsPad.ini, adding custom highlighters works fine.
Deleting 'standard highlighters' which u never would use, also ...
But: if you restart PsPad, the deleted 'standard highlighters' are back again.
As for I'm 'processing' *.htm files on the server with vb.net, I wanna use the created custom highlighter for all files processed with vb.net, but PsPad insists in highlighting *.htm files with the .htm-highlighter ...
Any workaround out there, or is it possible to prevent the standard-htm-highlighter from coming back?
#2 Re: PsPad.ini modifications not as expected
Posted by: pspad | Date: 2020-07-09 05:39 | IP: IP Logged
Stanfard (internal) highlighters can't be deleted, they can be deactivated only - uncheck ceckbox before highlighters you don't want to use in the highlighter list
