You are here: PSPad forum > English discussion forum > Re: Access Violation
Posted by: ppetree | Date: 2020-07-08 00:00 | IP: IP Logged
Sorry, I couldn't report this through your tool but I kept getting the alert() popup.
How I got there:
Had several files open in a project, created a new file (unsaved) and pasted two lines of xml code into it. Saved the project without saving the XML file. Switched to another project, I was prompted to save the xml file (I didn't) and I was prompted to close the project (I did) and then got this:
[img]https://drive.google.com/file/d/12NLBUcwloOgd7tR8YDgKx_OHdbXSdDEf/view?usp=sharing
[/img]
If the image doesn't show up, you can snag it here drive.google.com
Posted by: pspad | Date: 2020-07-08 05:50 | IP: IP Logged
You didn't write the most important thing - PSPad version
Problem related to yours was fixed in the PSPad 5.0.4 version what is available in the PSPad developer forum: : www.pspad.com
Replace existing files with content of archive.
Posted by: ppetree | Date: 2020-07-09 00:25 | IP: IP Logged
Sorry... I was at 5.0.3 (377). Last time I checked it was the latest! LOL
