You are here: PSPad forum > English discussion forum > Cannot save index.html
#1 Cannot save index.html
Posted by: Extranjero | Date: 2020-06-26 18:07 | IP: IP Logged
I can save all files (of any file-type/extension, even html) but not the file index.html once it was opened on localhost (for example via http-serve).
Closing localhost-connection/shutdown local server doesn't change behavior.
Sometimes the error-message is 'error on saving ...', sometimes PsPad runs directly in a memory error and needs to be restarted.
Opening the file index.html in another text-editor (for example notepad.exe) and edit/save it doesn't cause any problems, even with localhost serving and/or opened in PsPad at the same time.
Is there any solution/workaround out?
#2 Re: Cannot save index.html
Posted by: pspad | Date: 2020-06-26 18:30 | IP: IP Logged
Program settings / direct edit
Try to set:
SafeFileSave=1
DontChangeFileAtribute=1
#3 Re: Cannot save index.html
Posted by: Extranjero | Date: 2020-07-05 07:01 | IP: IP Logged
works ... thx
