You are here: PSPad forum > English discussion forum > Re: Saving files before calling a Tool
Posted by: tmpad | Date: 2020-06-19 19:58 | IP: IP Logged
In the "Project Settings..." I can check "Save all files before external application start".
I prefer to run external applications from "Tool Panel | Favourites | Tools" because I use most of them in multiple projects or even independent of any project.
In this case, only the current file is saved when I start the application. I would like to have the option to save all files.
I think to remember that it actually worked that way in previous versions (4.x?).
Edited 1 time(s). Last edit at 2020-06-19 19:58 by tmpad.
Posted by: pspad | Date: 2020-06-19 20:15 | IP: IP Logged
I see the compiler option "save all files" is missing in tools settings. I will add it.
