You are here: PSPad forum > English discussion forum > Re: PSPad unicode 5.0.4 (502) feature incomplete
Posted by: Gabriel_ACE | Date: 2020-06-04 13:56 | IP: IP Logged
Hi!!
I loved the new version that now highlights the text in other parts of the document when they are repeated
BUT
in my opinion this function is incomplete since if the document has several pages we cannot be sure that there are more occurrences without having to go line by line looking for the highlight
I suggest adding a popup message that counts the number of occurrences (ONLY when there are more than one) , like this:
and a new option to enable and disable this new function (the message) to prevent the PSPAD from freezing if there are too many occurrences
Edited 1 time(s). Last edit at 2020-06-04 13:56 by Gabriel_ACE.
Posted by: pspad | Date: 2020-06-04 16:54 | IP: IP Logged
This isn't search function. It doesn't know number of occurences.
It paint same search as selected. Nothing else.
If you will keep selection and you will scroll over your document (e.g. with mouse), you will see occurences over whole document. But I don't know number of them.
Highlighting is done only on visible part of page.
If you mean when you select text, PSpad should search over whole document, count occurences an do it every time when you change selection, it isn't possible. Can you imagine to do it in few MB large document?
Posted by: Gabriel_ACE | Date: 2020-06-05 12:51 | IP: IP Logged
pspad:HelloThis isn't search function. It doesn't know number of occurences.
Highlighting is done only on visible part of page.If you mean when you select text, PSpad should search over whole document, count occurences an do it every time when you change selection, it isn't possible. Can you imagine to do it in few MB large document?
I figured, but
how about a new feature like
the button in the search menu that counts the occurrences
when you highlight a text then you will be able to press a keyboard shortcut that counts and displays a message with the total occurrences
you could use the source code that is available on the PSPAD and just add a keyboard shortcut
what is your opinion?
