You are here: PSPad forum > English discussion forum > Re: Size of toolbar icons
Posted by: feef | Date: 2020-05-25 07:24 | IP: IP Logged
Hi Jan. Size of toolbar icons changes after restart. But when you click apply, the size becomes the same. You can see it here imgur.com
Posted by: pspad | Date: 2020-05-25 07:57 | IP: IP Logged
Thank you for info. I will try to find what causes it.
Posted by: pspad | Date: 2020-05-25 08:11 | IP: IP Logged
Maybe I know. PSpad increases size of toobar icons in case he found a higher resolution or DPI. In this case instead of stadard 16x16 icons 24x24 are used.
In your case you have Silk toolbar what isn't available in higher resolutions.
This change will be aplied when PSpad detects different monitor next time.
If you change it and save it, PSpad should keep it.
Please check [x]Don't change toolbar icon size when DPI is changed under settings of tollbar icons.
I will check why is it done for Sild, when Silk isn't available in bigger sizes.
Posted by: feef | Date: 2020-05-25 08:19 | IP: IP Logged
pspad:Please check [x]Don't change toolbar icon size when DPI is changed under settings of tollbar icons.
It doesn't have any effect
Posted by: pspad | Date: 2020-05-25 08:21 | IP: IP Logged
With this option PSPad shouldn't change size for next start.
Posted by: feef | Date: 2020-05-25 08:33 | IP: IP Logged
PSPad changes size anyway. On the GIF above this option is checked
Posted by: feef | Date: 2020-05-25 09:01 | IP: IP Logged
I understood. The size changes due to the fact that I have a scale of 125% in System > Display > Scale and layout . When I set the scale to 100% then everything works fine. It will help you.
Edited 1 time(s). Last edit at 2020-05-25 09:02 by feef.
Posted by: feef | Date: 2020-05-27 16:17 | IP: IP Logged
Jan Can you please give me some news about fixing the bug?
Posted by: pspad | Date: 2020-05-27 16:56 | IP: IP Logged
feef:Jan Can you please give me some news about fixing the bug?
It's fixed already. Wait for next build please
Posted by: feef | Date: 2020-05-28 05:31 | IP: IP Logged
Thanks a lot! Good news! )
