You are here: PSPad forum > English discussion forum > Features request: Scroll past EOL / Scroll past EOF
Posted by: core.dump | Date: 2020-04-03 08:48 | IP: IP Logged
dunno if this is the right place, but I think it would be nice (and useful, of course) to have in PSPad a feature like "cursor can't go beyond the end of line" and the possibility to write multiple lines at once (currently only deleting is possible, not writing).
Thanks
Subject adjusted by Moderator.
Edited 1 time(s). Last edit at 2020-07-09 14:24 by Stefan.
Posted by: pspad | Date: 2020-04-03 09:25 | IP: IP Logged
First request - program settings / Editor 1
switch off possibility to go behind EOL and EOF
Write several lines at once isn't as easy as it looks like. But it's in my ToDo
Posted by: core.dump | Date: 2020-04-04 10:41 | IP: IP Logged
Oh, ok thanks, I didn't notice
BTW, is there the possibility to scroll beyond the last line of a file mantaining the "go beyond EOL" deactivated instead?
Edited 1 time(s). Last edit at 2020-04-04 10:43 by core.dump.
Posted by: pspad | Date: 2020-04-04 11:21 | IP: IP Logged
Program settings / editor 1
Scroll past eol eof
Posted by: core.dump | Date: 2020-04-04 12:56 | IP: IP Logged
Excuse me,
I think you didn't understand what I asked exactly. I will try to explain better.
I'd like to have, at the same time:
1. Scroll past EOL deactivated
2. Scroll past EOF activated
Two different and independent settings, not one for both! It would be useful to have that kind of "mixed" behavior.
Posted by: pspad | Date: 2020-04-10 17:06 | IP: IP Logged
It will be available in the next developer build
