You are here: PSPad forum > English discussion forum > tidy doesn't work for specific folder
Posted by: erkange | Date: 2020-03-31 08:57 | IP: IP Logged
We have started to use one drive.
Unfortunately our company name has some chinese letters.
for an html file, if i put it in desktop and apply tidy it works.
But it doesn't work in one drive. I guess it is probably path of the folder.
Since path has chinese words.
what can i do?
Ps : portable version gives this error. prntscr.com
Installed version do nothing.
Posted by: pspad | Date: 2020-03-31 10:03 | IP: IP Logged
I will try to investigate if problem is in PSPad nebo in TiDy.
Maybe there is a wrong handling of file name when TiDy is started
Posted by: pspad | Date: 2020-04-10 17:30 | IP: IP Logged
Hello. The rpblem of question marks is problem of Dialog, showing info, there isn't problem in work with file path.
Your problem is caused by One drive.
Go to PSPad Program settings / Direct edit button.
In the [special settings] section change line
DontChangeFileAttribs=0
to
DontChangeFileAttribs=1
As Alternative you can try settings:
SafeSaveFile=1
This settings save file as temporary first, if save is successfull then delete original file and rename new file to it's original name.
Edited 1 time(s). Last edit at 2020-04-10 17:33 by pspad.
