You are here: PSPad forum > English discussion forum > Re: How to use it on 4k display?
#1 How to use it on 4k display?
Posted by: andresn | Date: 2020-03-30 08:00 | IP: IP Logged
The notes on the status bar (Cursor current position, encoding and so on) are too small it is impossible to read.
#2 Re: How to use it on 4k display?
Posted by: pspad | Date: 2020-03-30 08:25 | IP: IP Logged
Your PSPad version?
#3 Re: How to use it on 4k display?
Posted by: andresn | Date: 2020-03-30 10:00 | IP: IP Logged
5.0.3 (377)
#4 Re: How to use it on 4k display?
Posted by: pspad | Date: 2020-03-30 10:25 | IP: IP Logged
I found a problem. Fix will be availabel in the next developer build - available in developer forum
#5 Re: How to use it on 4k display?
Posted by: David in Delta | Date: 2020-04-22 23:09 | IP: IP Logged
More than the status bar changed when I installed 5.0.3 (377).
For example
Most of the toolbars were displayed (I don't want them - they take up space and I don't need them for what I do).
The tool panel opened on the left side (I've never wanted or needed to open it)>
I think the line numbers and ruler were turned off.
The font in the edit window changed to something smaller and darker than what I was using.
The syntax highlight colour changed.
The right edge stopped working for word wrap.
I think my customized settings were over-written during the upgrade. That never used to happen and I would prefer it not to when I upgrade.
#6 Re: How to use it on 4k display?
Posted by: pspad | Date: 2020-04-23 04:44 | IP: IP Logged
How did you installed new version?
Installer or portable?
Have you uninstall previous version first or install over it?
#7 Re: How to use it on 4k display?
Posted by: David in Delta | Date: 2021-01-02 23:23 | IP: IP Logged
I also figured out how to fix my line wrap problem. In Program Settings, Editor (Part 1), marking the box for Wrap (soft) with Right Edge makes the line wrap at the Position of Right Edge.
smiling smileysmiling smiley
