You are here: PSPad forum > English discussion forum > Re: Find Files - Exclude
#1 Find Files: how to Exclude specific folder?
Posted by: joemarfice | Date: 2020-03-29 20:36 | IP: IP Logged
I was able to figure out how to exclude files matching a pattern, by using the Add current button. I expected "*.zip" to exclude all zip files, but instead it's "file:*.zip". OK. Got it.
But I still can't figure out how to exclude folders matching "Archive". "*\Archive\" won't exclude them, for some reason.
Ideally, I'd like to exclude only folders exactly matching that - so "D:\Folder\Archive\" would be excluded, but "D:\Folder\Archive Settings" would not be excluded.
What's the correct formula to exclude folders?
Subject adjusted by Moderator.
Edited 1 time(s). Last edit at 2020-07-09 14:23 by Stefan.
#2 Re: Find Files - Exclude
Posted by: pspad | Date: 2020-03-30 03:52 | IP: IP Logged
Put there folder name without \
#3 Re: Find Files - Exclude
Posted by: joemarfice | Date: 2020-03-30 04:34 | IP: IP Logged
Never mind, I'm an idiot.
It's XYCopy that's giving me problems... a program I like almost as much as PSPad.
Thanks.
