You are here: PSPad forum > English discussion forum > Re: project file opens in new PSPAd instance?
#1 project file opens in new PSPAd instance?
Posted by: opto | Date: 2020-03-26 19:38 | IP: IP Logged
I am working on a Thunderbird addon which has js, html, css files and a manifest.json.
All files open in a tab, the json opens a new instance. Why? How can I change that? It is part of the project, so it belongs into a tab.
I open the files by doubleclicking in the file list tree on the left.
thanks,
Klaus
#2 Re: project file opens in new PSPAd instance?
Posted by: pspad | Date: 2020-03-26 20:09 | IP: IP Logged
JSON extension isn't known by PSPad.
PSpad opens from project known extension and unknown extensions are send to assigned application. So I don't know how did you assign PSpad to JSON.
Open menu settings / JavaScript
On the second tab is list of assigned extensions, add there *.json
From this moment PSpad will know JSON extension. Clicking on your manifest will open it as any other known file directly in PSpad
#3 Re: project file opens in new PSPAd instance?
Posted by: opto | Date: 2020-03-26 20:23 | IP: IP Logged
many thanks.
Yes, I knew that a long time ago. But mixed it up with the registered file type, where I entered json. (which obviously didn't help)
Just for other users: in most recent pspad, you find it at settings highliter settings <choose language> set extensions in File Masks
another thanks,
Klaus
