You are here: PSPad forum > English discussion forum > 5.0.3 (377) Folders created during install
#1 5.0.3 (377) Folders created during install
Posted by: Neil | Date: 2020-03-22 08:12 | IP: IP Logged
Hi Jan,
Sorry, but I must have missed when this changed.
When I install the latest version of PSPad, the installer creates the folder:
c:\Program Files\PSPad\PSPad editor
And puts all the files under "PSPad editor"
Why don't the files just go under:
I thought this is what used to happen.
Also I see an (x) after Help on the top row of options
i.e. Help(x) !!
Thanks,
Neil
#2 Re: 5.0.3 (377) Folders created during install
Posted by: pspad | Date: 2020-03-22 10:24 | IP: IP Logged
Default instllation path is %Program files%\PSPad editor
The (X) in the menu is fpor shortcut, cause "H" is used. When you press alt followed by X, you will get to Help menu
#3 Re: 5.0.3 (377) Folders created during install
Posted by: hhoefling | Date: 2020-03-22 10:34 | IP: IP Logged
You must select an Language.
After Start of PSPad without an directory "Language"
you becames the (x).
After (re)selecting the Language the (x) disapears.
by HH
#4 Re: 5.0.3 (377) Folders created during install
Posted by: pspad | Date: 2020-03-22 10:41 | IP: IP Logged
hhoefling:
(X) is in English localization. I guess it isn't present in other localizations
#5 Re: 5.0.3 (377) Folders created during install
Posted by: hhoefling | Date: 2020-03-22 13:38 | IP: IP Logged
Ok. That's right.
by HH
Edited 1 time(s). Last edit at 2020-03-22 13:38 by hhoefling.
