You are here: PSPad forum > English discussion forum > Re: How to create new file in javascript
Posted by: edo_nick | Date: 2020-02-28 10:47 | IP: IP Logged
I want to open new file in javascript just like click button Open file.
No open file dialog box just new tab (editor) appears.
When I use
neweditor.openFile(filename);
It went to error because file doesn't exist. (But I just want to create it.)
Thanks in advance.
Posted by: pspad | Date: 2020-02-28 11:35 | IP: IP Logged
There is few ways how to do it:
1. new file dialog: Ctrl+N, start typing: ja, move to Java script and confirm
2. always new file as JavaScript: program settings / Files - New default: Javascript. If you check Always this type, new file will be always Javascript. With unchecked option, new file will be same type as current file.
3. Click on the small arrow next new file button and choose JavaScript
Posted by: edo_nick | Date: 2020-02-28 12:12 | IP: IP Logged
Sorry, you quite don't understand my problem.
I want to use javascript to open new file (tab/editor).
I have written script to transform content of opened file and I want to put output of transformation into new file.
Posted by: vbr | Date: 2020-02-28 12:40 | IP: IP Logged
edo_nick:...
it should be possible to use the methods of the editor object via scripting:
newFile([file_name: string]) //... to create a new file tab in PSPad with the optional file name
text(string) // to set the file content
saveFile()
or possibly:
saveFileAs(file_name: string)
to actually save the file on disk.
(I am not sure, how the directory path is handled in this case - I personally use rather unsaved editor tabs for such output (via newFile(...) and text(...) only) and handle then the saving or discarding manually.)
hth,
Posted by: edo_nick | Date: 2020-02-28 12:47 | IP: IP Logged
Thank you. It works like that
var neweditor = newEditor ();
neweditor.newFile(filename);
text = newlines.join ("\n");
neweditor.text (text);
Posted by: Qwanturank26 | Date: 2020-03-04 15:43 | IP: IP Logged
Thanks for your response and script js ! It helped me alot !
