You are here: PSPad forum > English discussion forum > Re: Macros Dissapeared
Posted by: Esgrimidor | Date: 2020-02-20 21:31 | IP: IP Logged
I have observed recently my macro manager is empty
I am running a portable version of pspad from windows 10 home.
Y:\PORTABLES\DESARROLLO\PSPad\PSPad.exe
In windows 8.1 i have not problem.
Do you know what I am doing bad ?
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2020-02-20 21:33 | IP: IP Logged
Do you recommend me this version : autoit.de
I have still the problem with my graphic card and pspad version 5.03 (367) 20/01/2020 9:23:40
Best Regards
Nice program indeed
Posted by: pspad | Date: 2020-02-21 05:12 | IP: IP Logged
If you are running portable version, all files should be in the PSPad folder.
In the program settings / System check if Multiuser environment is disabled. If enabled config files are stored in user profile.
Macros are stored in .\MACRO subfolder of the PSpad main folder.
Are there any files? If not, copy it there
Posted by: Esgrimidor | Date: 2020-02-23 11:09 | IP: IP Logged
pspad:HelloIf you are running portable version, all files should be in the PSPad folder.
In the program settings / System check if Multiuser environment is disabled. If enabled config files are stored in user profile.Macros are stored in .\MACRO subfolder of the PSpad main folder.
Yes it's a portable installation I suppose. I will revise the old laptop with w8.1 and comment.
I think is clear.
Best Regards
Nice program indeed
Posted by: Esgrimidor | Date: 2020-02-23 11:17 | IP: IP Logged
I think my installation is portable but I have this also :
C:\Users\JOSE\AppData\Roaming\PSpad
the executable is from
so I have sure a little mess and is my problem.
I will revise everything
I don't see that folder....
Nice program indeed
Edited 1 time(s). Last edit at 2020-02-23 11:20 by Esgrimidor.
Posted by: Esgrimidor | Date: 2020-02-23 11:21 | IP: IP Logged
In the C:\Users\JOSE\AppData\Roaming\PSpad
i have :
Nice program indeed
Posted by: Esgrimidor | Date: 2020-02-23 13:26 | IP: IP Logged
I think I know what happened. Sure it's my fault.
Seems to be I have installed some day in the past pspad as a portable app. But probably mantaining some parts in the system.
So probably I used a system installer....
Then , when change the laptop, copy the main directory folder in Y:
But not the roaming folder....
So I have now the macro folder anywhere.
I have obtain copy of that folder from the old laptop.
I am going to put in the new folder under windows 10 and comment....
Nice program indeed
Posted by: Esgrimidor | Date: 2020-02-23 14:15 | IP: IP Logged
I close the program after copying the macros folder to the ubication.
Reopen and now the macros appear.
Best Regards
Nice program indeed
