You are here: PSPad forum > English discussion forum > Re: Support "Search and replace content in all files?"
#1 Support "Search and replace content in all files?"
Posted by: maki | Date: 2020-02-16 15:18 | IP: IP Logged
I have a lot of files without extension, and in each file I want to change the text and save the changes with encoding.
Unfortunately, there is no text editor that could handle this task? Impossible in PSPad.
Dir: C:\Project\Many MultipleFiles
Include: Sub-Folder
Find: some text
Replace with: some other text
File Types: ^[^.]*$
Edited 2 time(s). Last edit at 2020-02-16 15:19 by maki.
#2 Re: Support "Search and replace content in all files?"
Posted by: pspad | Date: 2020-02-16 15:29 | IP: IP Logged
First - move files into work folder - you don't need to care of what files you want to work with
Second - change encoding to one common
Third - make replace
All steps are logical and don't depend of the editor. But user with brain is required
#3 Re: Support "Search and replace content in all files?"
Posted by: maki | Date: 2020-02-16 16:26 | IP: IP Logged
Start worrying when you have countless files, especially those of extremely small size.
I want to see that he did it PSPad.
You haven't even tried Replace 1000.000.000.000 words smiling smiley and you tell me I don't have a brain.
Edited 1 time(s). Last edit at 2020-02-16 16:27 by maki.
#4 Re: Support "Search and replace content in all files?"
Posted by: pspad | Date: 2020-02-16 16:41 | IP: IP Logged
For any case you have to find coresponding tool. Any tool isn't universal for everything
And cause I don't need to do your work and your work isn't related to PSPad, you need to find another forum.
In your case I suggest you to start with databases. You can store your file content as database records, index it and manipulaye content with data manipulation language.
#5 Re: Support "Search and replace content in all files?"
Posted by: maki | Date: 2020-02-16 16:52 | IP: IP Logged
Well I have exhausted all computer resources - STACK OWERFLOW and BSOD (crash system) /PSPad
I have a tool that will open a really unimaginably large file. But it won't open many files with the same total size.
(1 file) Total Size: 2GB Replace: 10.000.000 words = 8 second replace
(1M file) Total Size: 2GB (Not work or not support)
Edited 2 time(s). Last edit at 2020-02-16 16:53 by maki.
#6 Re: Support "Search and replace content in all files?"
Posted by: maki | Date: 2020-02-16 18:25 | IP: IP Logged
Please help me how to turn off loading of 100000+ tabs during startup PSPad (because it cannot be handled).
I want Reset/Abort this Action.
Edited 1 time(s). Last edit at 2020-02-16 18:26 by maki.
#7 Re: Support "Search and replace content in all files?"
Posted by: pspad | Date: 2020-02-16 18:38 | IP: IP Logged
Program settings / files
#8 Re: Support "Search and replace content in all files?"
Posted by: maki | Date: 2020-02-16 18:43 | IP: IP Logged
SOLVED batch word find and replace smiling smiley Unlimited Files
Edited 1 time(s). Last edit at 2020-02-16 18:43 by maki.
Editor PSPad - freeware editor, © 2001 - 2020 Jan Fiala, Hosted by Webhosting TOJEONO.CZ, design by WebDesign PAY & SOFT, code Petr Dvořák, Privacy policy and GDPR
