You are here: PSPad forum > English discussion forum > Feature Request: per-project tab settings
Posted by: gwinkless | Date: 2020-02-16 12:33 | IP: IP Logged
Hi
Just a thought.
Working on a couple of different projects that have explicit tab requirements, it would be really nice to be able to switch between them without having to change program settings.
Geoff
Posted by: pspad | Date: 2020-02-16 12:54 | IP: IP Logged
Can you be more specific? what is different tab settings for you?
Posted by: gwinkless | Date: 2020-02-16 17:37 | IP: IP Logged
pspad:HelloCan you be more specific? what is different tab settings for you?
Work has a requirement that all tabs are converted to 2-spaces, while an Open Source project I'm working on insists on real tabs.
Now switching between is hardly the end of the world - it's three clicks, after all, but being able to save the same settings you currently have under "Editor Settings (part 2)" for "Real Tabs" and "Tab Width" for each project would be a nice touch.
Posted by: pspad | Date: 2020-02-16 17:47 | IP: IP Logged
I have way how to handle it immediately.
Enough is to have 2 PSpad folders (out of program files) with different config - for each project type one PSPad
I will try to find a way, maybe move this parameter to project config project.
