You are here: PSPad forum > English discussion forum > PSPad> Export...
PSPad> Export...
#1 PSPad> Export...
Posted by: maki | Date: 2020-02-15 15:41 | IP: IP Logged
PSPad> Export...
Where is the import option? I want to import many files at once.
Open CTRL O cannot perform this operation. Probably because of too many files at once.
I want Combine / Merge Multiple HTML files.
I probably need the 64-bit version and powerful processing engine (reduced RAM usage).
#2 Re: PSPad> Export...
Posted by: pspad | Date: 2020-02-15 15:45 | IP: IP Logged
What does mean too many?
Use copy command in dos window. It can join many files into one.
But if you need to use only e.g. Urls, is better to copy lines with urls only into result file.
#3 Re: PSPad> Export...
Posted by: maki | Date: 2020-02-15 15:50 | IP: IP Logged
I don't like DOS because it's too slow to perform task.
150K
html
#4 Re: PSPad> Export...
Posted by: pspad | Date: 2020-02-15 16:16 | IP: IP Logged
You are wrong
#5 Re: PSPad> Export...
Posted by: maki | Date: 2020-02-15 17:39 | IP: IP Logged
Can Combine copy/b *.html combined.html, but I still want additional settings during the process: Tidy
For details on these options:
tidy.sourceforge.net
#6 Re: PSPad> Export...
Posted by: pspad | Date: 2020-02-15 17:42 | IP: IP Logged
Use the tidy on your files first, then you combine it with COPY.
But again, it's out of PSPad topic. If you don't have questions related to PSpad, use tidy support or Microsoft support for MS DOS commands.
Edited 1 time(s). Last edit at 2020-02-15 17:44 by pspad.
#7 Re: PSPad> Export...
Posted by: maki | Date: 2020-02-15 17:54 | IP: IP Logged
I know the commands, I have Tidy applications, but I don't know the DOS command
Mini-Example:
drop-proprietary-attributes: yes
numeric-entities: yes
break-before-br: no
Editor PSPad - freeware editor, © 2001 - 2020 Jan Fiala, Hosted by Webhosting TOJEONO.CZ, design by WebDesign PAY & SOFT, code Petr Dvořák, Privacy policy and GDPR
