You are here: PSPad forum > English discussion forum > Shift+Ctrl+A
Shift+Ctrl+A
#1 Shift+Ctrl+A
Posted by: massimobalestra | Date: 2020-01-25 23:53 | IP: IP Logged
in the last few versions I noticed a strange behavior.
I have the syntax highlight enabled and I am editing a perl script.
If I select Format --> Add Remove comment it does a single line comment as expected.
But if I use the shortcut Shift+Ctrl+A it opens the Tool Panel, as if I pressed Ctrl+F2.
If I press again Shift+Ctrl+A nothing happens and to close the Tools Panel I have to press Ctrl+F2.
I tried to change the Syntax Highlight to php and C++ and it behaves in the same way.
I tried in two different computers, both have PsPad version 5.0.3 (367) and Windows 10 version 1909 (OS build 18363.592).
I saw it some weeks ago, I don't know the version it started from.
It happens in both cases if I select multiple lines or the cursor is just on ne line.
Thank you
#2 Re: Shift+Ctrl+A
Posted by: pspad | Date: 2020-01-26 04:49 | IP: IP Logged
I found this problem few days ago too
Go to program settings, keymap
In the file section remove shortcut for show favourite
#3 Re: Shift+Ctrl+A
Posted by: massimobalestra | Date: 2020-01-26 14:33 | IP: IP Logged
It worked,
thank you
#4 Re: Shift+Ctrl+A
Posted by: vardhann | Date: 2020-02-10 13:19 | IP: IP Logged
ya thanks for sharing this .. it helped me... thank u
