You are here: PSPad forum > English discussion forum > I miss a few features ..
#1 I miss a few features ..
Posted by: hlk123 | Date: 2019-12-28 10:25 | IP: IP Logged
Till now I've used PSPad version 4.6.x. and I was satisfied.
Especially I used:
o Menu -> Format -> Char Change Case -> Capitalize
o Menu -> Format -> UTF-16 BE
Since today I use PSPad with the newest version.
And I miss the "old" features (see above).
How can I use the old features in the new version?
Thank you.
I wish you all a Happy New Year.
#2 Re: I miss a few features ..
Posted by: pspad | Date: 2019-12-28 11:29 | IP: IP Logged
First request still exists there - menu format - Char case change. Select text and use this feature
In the PSPad 5 work with code pages was rewritten and much more code pages is supported. If you want to save file in UTF-16BE, choose code page from Encoding menu.
If you don't see UTF-16 BE code page, click on the modify in the encoding menu and check Unicode UTF-16 BE. And you can uncheck code pages what are not relevant for you
