You are here: PSPad forum > English discussion forum > SQL dialect / syntax highlighting INI support
Posted by: Slowly | Date: 2019-12-18 17:32 | IP: IP Logged
I've been a registered user for many years. I've recently got a new job where I would like to use PSPad for HiveSQL development.
I've read that SQL dialect and syntax highlighting support is hardcoded in the EXE.
What would it take to bump, adding .INI support for SQL dialect / syntax highlighting to the next major version of PSPad?
Thanx,
John Bonifas
MS Applied Geospatial Science, Northern Arizona University
BS Geography, Arizona State University Tempe Campus
BS Applied Computing, Arizona State University West Campus
(480) 815-0679
www.linkedin.com
github.com
www.deckerd26354.net
www.hackerrank.com
Posted by: pspad | Date: 2019-12-18 18:08 | IP: IP Logged
You don't need to use internal SQL highlighter. Go to menu settings / User highlighter and create highlighter for your HideSQL.
In menu Settings / Highlighter settings uncheck internal SQL and assign your into on of free slots on the end of the list.
