You are here: PSPad forum > English discussion forum > Re: Double click in project tree opens file in new instance
#1 Double click in project tree opens file in new instance
Posted by: padfox | Date: 2019-10-11 10:57 | IP: IP Logged
when a file of a project is closed it can be opend with an double click. That file should then open in the current project instance, not in a new instance. How can I avoid this?
Many thanks and greetings
padFox
#2 Re: Double click in project tree opens file in new instance
Posted by: pspad | Date: 2019-10-11 12:11 | IP: IP Logged
What is the file extension? Does PSPad knows such extension? If not, add it into any highlighter.
You can use right click in project tree to see what happen with file.
