You are here: PSPad forum > English discussion forum > Old project files loaded
#1 Old project files loaded
Posted by: padfox | Date: 2019-09-19 10:31 | IP: IP Logged
Hello again,
since some weeks I have the problem that the old project files are loaded, not just one empty text page when I start a new instance of PSPad. I have carefully checked the corresponding settings.
I'm using PSPad 5.0.1 (312). Any hints are highly appreciated!
Many thanks and greetings
padFox
#2 Re: Old project files loaded
Posted by: pspad | Date: 2019-09-19 10:41 | IP: IP Logged
Press the New project button and close PSpad. This will close all open projects.
#3 Re: Old project files loaded
Posted by: padfox | Date: 2019-10-11 10:53 | IP: IP Logged
Hello Jan,
didn't solve the problem!
padFox
#4 Re: Old project files loaded
Posted by: pspad | Date: 2020-01-10 14:02 | IP: IP Logged
Check if you have write rights to Recent.ini file.
This file contains files from last session and open it when you start PSpad.
When you don't want PSPad open last edited files, go to program settings / Files and dirs and choose "Don't restore files" option for Save work/desktop
