You are here: PSPad forum > English discussion forum > Powershell string continuation
#1 Powershell string continuation
Posted by: clanman | Date: 2019-09-08 11:56 | IP: IP Logged
In Powershell you can have the following code:
$StraightAddr = 'Google LLC|1600 Amphitheatre Parkway|Mountain View, CA 94043|USA'
You can also have the same address in a string put together like this:
$FormattedAddr = 'Google LLC
USA'
In the case of $FormattedAddr PSPad does not highlight
USA
as a string. In fact it starts a new string after the "'" at the end of USA.
I know one could argue this is bad programming however since this is valid in the language is it possible for PSPad to recognise it for strings starting and ending with '' and "" that span multiple lines?
#2 Re: Powershell string continuation
Posted by: pspad | Date: 2019-09-08 12:25 | IP: IP Logged
Thank you for info. I have to add support for multiline strings
