You are here: PSPad forum > English discussion forum > Re: Sidebar Defaults
#1 Sidebar Defaults
Posted by: rontarrant | Date: 2019-08-16 13:15 | IP: IP Logged
Whenever I open PS Pad with the sidebar visible, it defaults to the Project view. Is it possible to have it default to the Folder/Directory hierarchy instead?
#2 Re: Sidebar Defaults
Posted by: rontarrant | Date: 2020-01-01 11:02 | IP: IP Logged
Just to wrap things up...
I'd actually forgotten about asking this question. For the first few weeks after my first post, I came back every few days to check and see if anyone had answered. But after a while, I let it slide and started looking for another editor.
And I found one. It's been quite a while now. Notepad++ has the above-described feature so I've moved on.
Thanks for everything.
#3 Re: Sidebar Defaults
Posted by: Professor Bernd | Date: 2020-01-27 13:26 | IP: IP Logged
Hello Jan.
I have the same request: Is it possible to save the view for the ToolPanel?
If the view for the fav scripts is open when you close PSPad, you should see the fav scripts the next time you start PSPad. That would be very nice. smiling smiley
Bernd.
#4 Re: Sidebar Defaults
Posted by: Vany | Date: 2020-01-27 13:30 | IP: IP Logged
My defaulting is to open to the Code Explorer (CE) and it works, but any other tab is ignored and always is the CE opened.
#5 Re: Sidebar Defaults
Posted by: pspad | Date: 2020-01-27 14:37 | IP: IP Logged
Because if you put Code explorer there, each time you open document, it's parsed and the result is shown there.
#6 Re: Sidebar Defaults
Posted by: Vany | Date: 2020-01-27 14:55 | IP: IP Logged
okay, thanks, it is reply to my comment, but I do not want to steal the prime topic of this thread - if you have opened the Project toolbar (without Code Explorer), is there any option to save the last chosen TAB, not always the first one?
#7 Re: Sidebar Defaults
Posted by: pspad | Date: 2020-01-27 14:58 | IP: IP Logged
Not yet. But I can add this option.
#8 Re: Sidebar Defaults
Posted by: Professor Bernd | Date: 2020-01-27 17:25 | IP: IP Logged
Thanks Jan, that would be great! smiling smiley
If it's not too much to ask, can you also add saving the view for the child notes for Au3 files? If a child note is collapsed / expanded, that it will be collapsed / expanded again after a restart of PSPad?
Vany:
My defaulting is to open to the Code Explorer (CE) ..., but any other tab is ignored and always is the CE opened.
Thank you both for the very interesting hint. I have now placed the Code Explorer in the Tool Panel, and the Fav Scripts I have placed on the right side of PSPad. Every time I start PSPad, this view is restored. This helps in the meantime until the feature to restore the last tab is added. tongue sticking out smiley
Now it looks like this.
Bernd.
#9 Re: Sidebar Defaults
Posted by: pspad | Date: 2020-01-27 20:18 | IP: IP Logged
I will make variables declaration in autoit collapsed
#10 Re: Sidebar Defaults
Posted by: Professor Bernd | Date: 2020-01-28 00:55 | IP: IP Logged
Thanks smiling smiley
