You are here: PSPad forum > English discussion forum > Re: MS VBScript files not highlighted
#1 MS VBScript files not highlighted
Posted by: joemarfice | Date: 2019-07-11 18:40 | IP: IP Logged
The highlighter function works fine for other files, like *.bat and *.bas, but the *.vbs and *.asa files are not recognized. WSH scripting is turned on. The VBS extension is only assigned to MS VBScript.
Can someone suggest what I'm missing?
#2 Re: MS VBScript files not highlighted
Posted by: pspad | Date: 2019-07-11 19:12 | IP: IP Logged
Maybe your file is too big. There is limit for automatic highlight.
Open program settings / Direct edit
Find line HLUpToSize and change value e.g. to 500000
You can anytime activate code highlight manually by toolbar button or in the menu View / Syntax
On the statusbar should be highlighter name, if highlighter is recognized by file extension
