You are here: PSPad forum > English discussion forum > Re: Why does this regex require an additional "case-sensitive" option?
Posted by: maki | Date: 2019-07-02 10:44 | IP: IP Logged
Like a different regex, but it also has the same application, so why are there two types?
[A-Z] = big and small letter match
[a-z] = big and small letter match
Posted by: pspad | Date: 2019-07-02 12:13 | IP: IP Logged
Case sensitive option is part of the regular expression. You can switch it on/off.
PSpad does it in Search dialog, if you use regular expressions in script, you need to set it by your own
Posted by: maki | Date: 2019-07-02 14:46 | IP: IP Logged
(i?)[A-Z]
(?-i)[A-Z]
(?i) case-insensitive mode ON
(?-i) case-insensitive mode OFF
How to find only capital word?
Edited 1 time(s). Last edit at 2019-07-02 14:48 by maki.
Posted by: Vany | Date: 2019-07-04 09:10 | IP: IP Logged
Hi, for whole word, you could try to search for "(?-i)\b[A-Z]{2,}\b
", if you want to find even letters alone, it's simpler "(?-i)\b[A-Z]+\b
Posted by: maki | Date: 2019-07-04 11:45 | IP: IP Logged
^(?-i)[A-Z]+$
You can use two more options, but one of the options unfortunately does not work, so you have to add ^ $
Edited 1 time(s). Last edit at 2019-07-04 11:49 by maki.
Posted by: Vany | Date: 2019-08-13 17:41 | IP: IP Logged
but your version finds only upper case word on a separate line
