You are here: PSPad forum > English discussion forum > Usability
Usability
#1 Usability
Posted by: felafel | Date: 2019-06-11 05:41 | IP: IP Logged
Many times I added text to the begin/end of lines and also I added numbers. To do so I needed to open two times "Insert Text into Lines..." mask
imgur.com
IMHO, if you add the button "Apply" you don't need to press the "OK" button and then open again the mask to complete your work.
What I'm trying to say is that you click "Apply" first time and then click it again when you have modified your lines modification task.
I hope it's clear
Edited 1 time(s). Last edit at 2019-06-11 05:42 by felafel.
#2 Re: Usability
Posted by: pspad | Date: 2019-06-11 10:03 | IP: IP Logged
This should be no problem. I will add it into ToDo list
#3 Re: Usability
Posted by: pspad | Date: 2020-01-16 20:17 | IP: IP Logged
Added. Available in the next build
