You are here: PSPad forum > English discussion forum > Crash when editing file in hex mode
Posted by: pspad | Date: 2020-01-12 17:31 | IP: IP Logged
No, the log is in memory only.
I will try make more tries. Maybe I will be sucessfull in simulation.
Can I get the short file from your video, where one line is wider and from this line problems started?
Posted by: jojo | Date: 2020-01-12 17:35 | IP: IP Logged
Here is the file: manx.datengang.de
I have observed another failure mode while trying to reproduce the issue with a similarly-sized file, this time I got "List index out of bounds (1)" instead of the Access Violation and I was able to copy the log, but I fear it won't be very helpful:
Exception address: 00405D7A
Stack list, generated 12/01/2020 18:32:12
(00004D7A) [00405D7A]
Posted by: pspad | Date: 2020-01-12 17:59 | IP: IP Logged
After many tests I got exception with error log.
Problem is in hex editor component change handling. Fix won't be easy, if possible.
Maybe I will need to look for another hex editor component
