You are here: PSPad forum > English discussion forum > Re: Crash when editing file in hex mode
Posted by: jojo | Date: 2019-06-04 16:39 | IP: IP Logged
Using PSPad 32-bit version 5.0.1 (312) on Windows 10 Professional x64, I can reliably crash the application by opening a file in hex editor mode and then just keeping a key pressed to overwrite a sequence of bytes. After a while, I either get an access violation message box or the application just shuts down without any notice. The amount of bytes after which this occurs differed on two machines I tested this on, sometimes it was after less than 64 bytes, in other cases it took up to overwritten 256 bytes until the application would crash.
Posted by: pspad | Date: 2019-06-04 17:06 | IP: IP Logged
Can you repeat your problem with version 5.0.2? Available in developer forum
Posted by: jojo | Date: 2019-06-04 20:12 | IP: IP Logged
It also crashes with version 5.0.2 321 (32-bit).
Posted by: pspad | Date: 2019-06-05 03:48 | IP: IP Logged
Can you send me the exception log to the support mail?
Posted by: jojo | Date: 2019-06-05 06:56 | IP: IP Logged
Unfortunately the crash dialog doesn't show up as the application just shuts down immediately. Is there another way to generate a log for you?
Posted by: jojo | Date: 2020-01-11 17:06 | IP: IP Logged
This is still happening in 5.0.2, but not always. When it does, PSPad now just hangs, without showing a crash dialog.
Posted by: pspad | Date: 2020-01-11 17:20 | IP: IP Logged
Download pkease current 5,0,3 build. Try to describe how to get exception. If i will be able to simulate it, it would be easier to fix it
Posted by: jojo | Date: 2020-01-11 17:34 | IP: IP Logged
It also happens with the latest developer build.
All I'm doing is:
1. Open a file in hex editor mode
2. Start typing into the hex view
I have figured out that the behaviour changes depending on the size of the file.
Here are two videos of what happens when I hex-edit a file of 26 KB (the editor goes crazy!) and a 1 MB file (crash dialog):
Posted by: pspad | Date: 2020-01-12 17:26 | IP: IP Logged
Hello. Can you send me the LOG?
I am trying to simulate it with 256kB file, but I am not sucessfull to get exception.
Edited 1 time(s). Last edit at 2020-01-12 17:28 by pspad.
Posted by: jojo | Date: 2020-01-12 17:27 | IP: IP Logged
Do you mean the log that is seen in the dialog? As you can see in the video, I cannot access the window with the log because the Access Violation dialog keeps popping up in front of it. Is there another way to access the log, e.g. is it written to a file?
