You are here: PSPad forum > English discussion forum > Backgroud Colour setting
#1 Backgroud Colour setting
Posted by: ejfield | Date: 2019-04-04 12:59 | IP: IP Logged
I've just installed 5.0.2(319) 64b version.
If I change the background colour, the main edit window, Log, Search Results, and FTP windows all take the new colour, but the "Search in Files Results" window background remains white. Very odd.
#2 Re: Backgroud Colour setting
Posted by: Angelset | Date: 2019-04-05 06:40 | IP: IP Logged
Yes, same for me..
#3 Re: Backgroud Colour setting
Posted by: pspad | Date: 2019-04-05 07:21 | IP: IP Logged
There was a problem with userdraw treeview component, so I was forced to remove it.
With different windows IDE (Window 7 is different from Windows 10), themes e.t.c. is situation more and more complicated on the background.
I will allow themes for application, but it will take a while. Cause using of themes needs different message handling.
