You are here: PSPad forum > English discussion forum > Re: Comment out block
Posted by: target232 | Date: 2019-04-03 11:16 | IP: IP Logged
Hi
After upgrading I'm unable to comment out block of lines (using Ctrl+Shift+A)
I have custom ASP.INI / ASP.DEF files but commenting will not work in any file .js .html .asp ... etc
After selecting text and pressing Ctrl+Shift+A nothing happens.
Is there a way to troubleshoot this problem ?
Posted by: pspad | Date: 2019-04-03 11:26 | IP: IP Logged
Hello.
Your highlighter is ASP or HTML multihighlighter?
If you want to use definition from ASP, you need to switch highlighter to ASP or remove ASP from HTML multihighlighter.
Where is defined your comment? In the DEF file with shortcut?
In this case you need to remove standard shortcut for Comment/uncomment (menu Format)
Posted by: target232 | Date: 2019-04-03 14:47 | IP: IP Logged
I remove ASP from HTML multihighlighter (put visual basic there) - no effect
switched from HTML multihighlighter to ASP - no effect
in User Highlighter deinition:
Comment style: ' checked
here is file dump
c:\Program Files (x86)\PSPad editor\Syntax\asp.ini
[Settings]
Name=ASP
HTMLGroup=1
Vectors=0
Label=1
FileType=*.aspx
CommentString='
SinglQComment=1
IndentChar=4
UnIndentChar=4
TabWidth=2
SingleQuote=1
DoubleQuote=1
EscString=1
EscChar=\
KeyWordChars=-_
CodeExplorer=ftVBS
DocComment=
[KeyWords]
AS=
CALL=
CASE=
CATCH=
CLASS=
CONST=
DIM=
DO=
EACH=
ELSE=
ELSEIF=
EMPTY=
END=
ERASE=
ERR=
ERROR=
EXECUTE=
EXECUTEGLOBAL=
EXIT=
EXPLICIT=
FALSE=
FOR=
FUNCTION=
IF=
IN=
ISNOT=
LOOP=
NEW=
NEXT=
NOT=
NOTHING=
NULL=
ON=
OPTION=
PRIVATE=
PROPERTYGET=
PROPERTYSET=
PUBLIC=
RANDOMIZE=
REDIM=
RESUME=
RETURN=
SELECT=
SET=
SUB=
THEN=
TO=
TRUE=
TRY=
WEND=
WHILE=
WITH=
[ReservedWords]
ABS=
AND=
ANDALSO=
ARRAY=
ASC=
ATN=
BOOLEAN=
Byte=
CBOOL=
CBYTE=
CCUR=
CDATE=
CDBL=
CHR=
CINT=
CLNG=
CONCAT=
COS=
CREATEOBJECT=
CSNG=
CSTR=
DATE=
DATEADD=
DATEDIFF=
DATEPART=
DATESERIAL=
DATETIME=
DATEVALUE=
DAY=
Double=
Encoding=
Exception=
EXP=
FILTER=
Float=
FORMAT=
FORMATCURRENCY=
FORMATDATETIME=
FORMATNUMBER=
FORMATPERCENT=
GETLOCALE=
GETOBJECT=
GETREF=
GetRequestStream=
HEX=
HOUR=
HttpWebRequest=
HttpWebResponse=
INDEXOF=
INPUTBOX=
INSERT=
INSTR=
INSTRREV=
INT=
INT16=
INT32=
INT64=
INT8=
Integer=
ISARRAY=
ISDATE=
ISEMPTY=
ISNULL=
ISNUMERIC=
ISOBJECT=
JOIN=
LBOUND=
LCASE=
LEFT=
LEN=
LENGTH=
LOADPICTURE=
LOG=
Long=
LTRIM=
MailMessage=
MatchCollection=
MATCHES=
MID=
MINUTE=
MONTH=
MONTHNAME=
MSGBOX=
NOW=
OCT=
OR=
ORELSE=
REGEX=
REPLACE=
RGB=
RIGHT=
RND=
ROUND=
RTRIM=
SCRIPTENGINE=
SCRIPTENGINEBUILDVERSION=
SCRIPTENGINEMAJORVERSION=
SCRIPTENGINEMINORVERSION=
SECOND=
SERVER=
SETLOCALE=
SGN=
SHA256Managed=
SHA512Managed=
SIN=
SmtpClient=
SPACE=
SPLIT=
SqlDataReader=
SqlPaameter=
SQR=
STRCOMP=
Stream=
StreamReader=
StreamWriter=
STRING=
STRINGBUILDER=
TAN=
TextReader=
TIME=
TIMER=
TIMESERIAL=
TIMEVALUE=
TRIM=
TYPENAME=
UBOUND=
UCASE=
UTF8Encoding=
VARTYPE=
WEEKDAY=
WEEKDAYNAME=
X509Certificate=
X509Certificate2=
X509Store=
XElement=
XML=
XmlDocument=
XmlReader=
XOR=
YEAR=
[KeyWords2]
Add=
Append=
AppendAllLines=
AppendAllText=
AppendLine=
AppendText=
Application=
Clear=
Close=
Contains=
Convert=
Copy=
Delete=
Dispose=
EndsWith=
Equals=
ExecuteNonQuery=
ExecuteReader=
ExecuteScalar=
Exists=
Form=
IsNullOrEmpty=
Move=
Open=
OpenRead=
OpenText=
OpenWrite=
QueryString=
Read=
ReadAllBytes=
ReadAllLines=
ReadAllText=
ReadToEnd=
Redirect=
Request=
Request.Form=
Request.QueryString=
Response=
Response.End=
Response.Flush=
Response.Redirect=
Response.Write=
Server=
ServerVariables=
Session=
StartsWith=
SubString=
ToLower=
ToString=
ToUpper=
Write=
[KeyWords3]
addressOf=
byRef=
byVal=
vbCr=
vbLf=
vbNewLine=
vbTab=
IT WORKS FROM menu->Format->Add/Remove comment
Looks like it's not PSPad problem but windows 'cos something else already bind Ctrl+Shift+A shortcut
Thanks for troubleshooting
