You are here: PSPad forum > English discussion forum > Re: default html code
#1 default html code
Posted by: ronbo | Date: 2019-03-07 08:01 | IP: IP Logged
When starting an HTML document the default html code is using the doctype for html 4. Where do I edit this to change the doctype to html 5?
#2 Re: default html code
Posted by: pspad | Date: 2019-03-07 09:17 | IP: IP Logged
It's template file Default.html in the subfolder Template
If you have PSpad installed in program files, you will need to run it as administrator to have rights to write there.
Easier way how to edit template:
Ctrl+N (new file)
Second tab - templates
Choose Default under HTML and button Modify
#3 Re: default html code
Posted by: ronbo | Date: 2019-03-07 16:18 | IP: IP Logged
Thanks, that worked!
