You are here: PSPad forum > English discussion forum > Re: Issue when you select too much text
#1 Issue when you select too much text
Posted by: hexaae | Date: 2019-02-26 21:25 | IP: IP Logged
When I drag mouse to select a lot of text I've seen the total counter for selected chars disappears suddenly… This happens with any file, just drag with LMB and select a lot of text vertically. After 2-3000 chars or more the bottom bar will switch from (f.e.) "98x0 [2125]" to "101x4" and won't show the total amount of selected chars anymore...
#2 Re: Issue when you select too much text
Posted by: pspad | Date: 2019-02-26 21:38 | IP: IP Logged
Current version is limited by 100 rows, in next build it will be increased to 1000 lines
#3 Re: Issue when you select too much text
Posted by: hexaae | Date: 2019-03-01 16:50 | IP: IP Logged
May I ask at least 10000 lines if it has no side-effects?
