You are here: PSPad forum > English discussion forum > Re: Error using Undo on Hex-Editor mode
Posted by: hexaae | Date: 2019-02-26 15:49 | IP: IP Logged
Repro steps:
1. open a file
2. switch to hex-editing mode
3. change hex values
4. press Undo button in the upper toolbar
at this point PSPad will report error:
Exception description:
Access violation at address 00407247 in module 'PSPad.exe'. Read of address 07838517.
Exception address:
Stack list, generated 26/02/2019 16:48:04
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Users\Luca\Util\pspad\PSPad.exe 5.0.1 (312)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 4563,
Processor: Intel, Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2200 MHz MMX
Active Controls Hierarchy:
TMPHexEditorEx ""
TfChildEdit "_"
Edited 1 time(s). Last edit at 2019-06-07 18:46 by Stefan.
Posted by: hexaae | Date: 2019-02-26 15:51 | IP: IP Logged
If Undo/Redo is not supported in Hex-Edit mode I suggest to grey out the Undo/Redo options and block also shortcuts for these operations.
