You are here: PSPad forum > English discussion forum > Feature Request - Native Multi-line Search/Replace
Posted by: dmittleider | Date: 2019-02-18 14:37 | IP: IP Logged
I have always used the phReplace and it works great but the need to register a DLL is a non-starter on a lot of systems (I do support work on lots of servers and PCs I don't have full access to where I just need a quick way to have something better than Notepad but it would take longer to get somebody to install and register everything than it's worth).
I love the interface to phReplace but worst case using the new line characters like how Notepad++ does it would work.
Thanks for all you do, I love PSPad!!!
Posted by: joemarfice | Date: 2019-04-02 17:40 | IP: IP Logged
Alternatively, adding a special character that matches CR/LF/CR+LF (each, or all) as Word has would be equally useful, IMO.
So, the Find string "ABC\nDEF" would match in a line that ends with "ABC" followed by a line that begins "DEF" - just in case I wasn't clear.
