You are here: PSPad forum > English discussion forum > Re: javascript pspad problem
#1 javascript pspad problem
Posted by: Gabriel_ACE | Date: 2019-02-11 15:30 | IP: IP Logged
hi!
I m trying to execute this sentence
var oneFile = moreFiles.item();
var n = oneFile.search(".sel");
echo(n);
but pspad don't like "search"
idem for "includes"
var n = oneFile.includes(".sel");
echo(n);
I don't understand which is the problem
#2 Re: javascript pspad problem
Posted by: pspad | Date: 2019-02-11 15:53 | IP: IP Logged
What does mean "pspad doesn't like search"?
#3 Re: javascript pspad problem
Posted by: vbr | Date: 2019-02-11 21:56 | IP: IP Logged
Gabriel_ACE:
hi!
echo(n);
idem for "includes"
echo(n);
it is difficult to find the cause of this problem without the rest of the code,
but there are some possibilities.
The type of the objects in questions is important - I believe, search is a string method and performs a regex search; it most likely is not available e.g. in an array.
incudes is an array method, but it might not be supported in all javascript engines, e.g. MS Explorer; I thing PSPad uses this browser for WSH scripting javascript, if it is present.
Could you possibly use indexOf in your code? (this seems more general and more widely available).
hth,
