You are here: PSPad forum > English discussion forum > Re: FTP with TLS does not show file list
Posted by: rcervantes | Date: 2019-01-29 16:34 | IP: IP Logged
I'm using PSPad to connect to my private FTP server which is configured to allow TLS connections in passive mode. I can connect to it but when tries to show file list an error is raised.
I can connect with no problems with FileZilla. Why this difference? I'm attaching some log from PSPad and Filezilla. Any help? I'm using proFTP in my FTP server.
Note: It is edited to hide information
PSPad LOG
SSL library: OpenSSL 1.0.2n 7 Dec 2017
Connecting to: xxxxxxxxxxxxx
220 FTP Server
AUTH TLS
234 AUTH TLS con exito
USER xxxxxx
331 Contrasa necesaria para user
PASS xxxxxx
230 Welcome to FTP server
PBSZ 0
200 PBSZ 0 exitoso
PROT P
200 Protection set to Private
TYPE I
200 Tipo establecido en I
STRU F
200 Estructura establecida a F
MODE S
200 Modo establecido en S
REST 0
350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer
REST 1
350 Restarting at 1. Send STORE or RETRIEVE to initiate transfer
REST 0
Certificate: @@@@
CWD /
250 Comando 'CWD' exitoso
TYPE A
200 Tipo establecido en A
PASV
227 Entering Passive Mode (yy,yy,yy,yy,yy).
LIST
150 Abriendo ASCII modo conexion de datos para file list
425 Imposible leventar conexion de datos: Operacion no permitida
FileZilla LOG
Status: Connection established, waiting for welcome message...
Response: 220 SPC-YELES FTP Server
Command: AUTH TLS
Response: 234 AUTH TLS con éxito
Status: Initializing TLS...
Trace: TLS Handshake successful
Trace: Protocol: TLS1.2, Key exchange: ECDHE-RSA, Cipher: AES-256-GCM, MAC: AEAD
Trace: Hostname does not match certificate SANs
Status: Verifying certificate...
Status: TLS connection established.
Command: USER user
Response: 331 Contraseña necesaria para user
Command: PASS ********
Response: 230 Welcome to FTP server
Command: OPTS UTF8 ON
Response: 200 UTF8 establecido en on
Command: PBSZ 0
Response: 200 PBSZ 0 exitoso
Command: PROT P
Response: 200 Protection set to Private
Status: Logged in
Trace: Measured latency of 16 ms
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/home/datos" es el directorio corriente
Command: TYPE I
Response: 200 Tipo establecido en I
Command: PASV
Response: 227 Entering Passive Mode (yy,yy,yy,yy,yy,yy).
Trace: Binding data connection source IP to control connection source IP 19x.x.x.x.x.
Command: LIST -a
Trace: Trying to resume existing TLS session.
Response: 150 Abriendo BINARY modo conexión de datos para file list
Trace: TLS Session resumed
Response: 226 Transferencia completada
Status: Directory listing of "/home/datos" successful
Posted by: pspad | Date: 2019-01-29 18:35 | IP: IP Logged
Hello Change Pure/Clear settings in your FTP connection
