You are here: PSPad forum > English discussion forum > cache?
Posted by: irdogg | Date: 2019-01-29 14:58 | IP: IP Logged
how do you clear all the auto complete? like search and replace i have never cleared all of that ever
Posted by: pspad | Date: 2019-01-29 18:34 | IP: IP Logged
Autocomplete is dynamically created from file content + from highlighter. It's not stored "somewhere". If we both talk about Ctrl+J - Autocomplete function
Posted by: vbr | Date: 2019-01-29 21:54 | IP: IP Logged
irdogg:how do you clear all the auto complete? like search and replace i have never cleared all of that ever
if I understand correctly, the previously used inputs in the dialog like search and replace, etc. are stored in
a file called Recent.INI
there are multiple section, e.g.:
[Find/Replace find history]
the file should be located either in the pspad folder (in the portable setting without user profiles
or in user profile folder of PSPad, where also the main configuration in PSPad.ini is stored.
hth,
