You are here: PSPad forum > English discussion forum > Re: Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-01-13 15:04 | IP: IP Logged
I observ is possible in pspad link to a web page.
Is it possible to link to a folder ?
to a file ?
to a programa ?
Best Regards
I observ there is an option in the contextual menu for Open Selected file in the default application .....
Any alternative ?
Nice program indeed
Posted by: Gabriel_ACE | Date: 2019-01-14 15:13 | IP: IP Logged
no
becauses how pspad will know if the string is path or only descriptive text ?
Posted by: Esgrimidor | Date: 2019-01-14 16:27 | IP: IP Logged
I think is the same problem with an URL, but an URL is recognized perhaps with the help of an addon or plugin.
I was doing proofs and notepad don recognize an URL (is not clickable). Notepad++ the same behaviour.
Therefore in a plain text file we have to use an interpreter..
By the moment I can launch a target folder with the contextual menu option I said before with no problem.
So I am writing the path in the line i want. Then select and right mouse clic and open selected file with default application.
This option (open selected file with default application) I think is from pspad, so perhaps i have that plugin or is a standard in the normal version.
Nice program indeed
Posted by: pspad | Date: 2019-01-15 14:11 | IP: IP Logged
Gabriel_ACE:nobecauses how pspad will know if the string is path or only descriptive text ?
No it can't to know it.
File/folder path can contain spaces, URL like protocols not. So PSpad isn't able to take general text and duess where is end.
example:
I have some folder like e:\some folder name\and some other path in my disk and I want to highlight this folder.
Where is the folder path end?
Posted by: Esgrimidor | Date: 2019-01-15 19:52 | IP: IP Logged
Anyway I am applying the option in the contextul menu Open Selected file with the default Application. Goes Wonderful !!!!!!!!!!!!!!!!
Is for a simple txt file i am using for year to write down my works.
Each work has a windows folder assigned.
Now I can go !!!!!!!!
I put by example :
436.18 Comprobación substitucion piezas por otras sin autori
Y:\GABINETE\PROYECTOS\436.18
I selected with the mouse the text Y:\GABINETE\PROYECTOS\436.18 and launch with the right click option of the mouse.
You can use too for programs, files, urls.....
Let me see with a .lnk file... :
No. I suppose because a lnk file there is not exist a default application to open it.
And a folder with spaces in the path ... :
Y:\DATOS PARA EL RECUERDO\coreldrw\curriculum y busqueda trabajo
Wonderfully opened !!!!!!!!
Can I launch PsPad from inside Pspad ?¿?¿?¿?¿?¿?¿
let me see
Y:\PORTABLES\DESARROLLO\PSPad\PSPad.exe
Eureka !!!!!!! It's working like a charm !!!!!!!!
I can launch video or audio files too
I have a script a long time ago to select a line of text. I am using the Control+. for this purpose
Can I have a script to select a text and remain selected to be launched ?
It was easy . I don't remember the environment : AHK, Autoit, phrase express.....
Can I with Pspad write a script for these and assign a hotkey ?
Nice program indeed
Posted by: Esgrimidor | Date: 2019-01-15 22:56 | IP: IP Logged
Can I do a script to select from the cursor to the beginning of the line and then select the option in the contextual menu Open Selected file with the default application ?
It's very interesting !!!!!
Nice program indeed
Posted by: Gabriel_ACE | Date: 2019-01-18 12:08 | IP: IP Logged
Esgrimidor:Can I do a script to select from the cursor to the beginning of the line and then select the option in the contextual menu Open Selected file with the default application ?It's very interesting !!!!!
eso que dijiste si se puede master! (ya me di cuenta que hablas españo como yo jajajaj)
Posted by: Esgrimidor | Date: 2019-02-01 00:11 | IP: IP Logged
Gabriel_ACE:Esgrimidor:Can I do a script to select from the cursor to the beginning of the line and then select the option in the contextual menu Open Selected file with the default application ?It's very interesting !!!!!
Can you do that script ? (puedes hacer ese programa ? )
Nice program indeed
Posted by: Gabriel_ACE | Date: 2019-02-01 19:42 | IP: IP Logged
disculpa, no tengo los conocimientos de javascript nesesarios para eso
si no con gusto te ayudaba
Posted by: Esgrimidor | Date: 2019-02-04 13:26 | IP: IP Logged
Ejem. I know is possible too. Now to wait someone that can help with the corresponding script.
Nice program indeed
