You are here: PSPad forum > English discussion forum > Link to a folder in a txt file is possible ?
#1 Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-01-13 15:04 | IP: IP Logged
I observ is possible in pspad link to a web page.
Is it possible to link to a folder ?
to a file ?
to a programa ?
Best Regards
I observ there is an option in the contextual menu for Open Selected file in the default application .....
Any alternative ?
Nice program indeed
#2 Re: Link to a folder in a txt file is possible ?
Posted by: Gabriel_ACE | Date: 2019-01-14 15:13 | IP: IP Logged
no
becauses how pspad will know if the string is path or only descriptive text ?
#3 Re: Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-01-14 16:27 | IP: IP Logged
I think is the same problem with an URL, but an URL is recognized perhaps with the help of an addon or plugin.
I was doing proofs and notepad don recognize an URL (is not clickable). Notepad++ the same behaviour.
Therefore in a plain text file we have to use an interpreter.. tongue sticking out smiley
By the moment I can launch a target folder with the contextual menu option I said before with no problem.
So I am writing the path in the line i want. Then select and right mouse clic and open selected file with default application.
This option (open selected file with default application) I think is from pspad, so perhaps i have that plugin or is a standard in the normal version.
smiling smiley
Nice program indeed
#4 Re: Link to a folder in a txt file is possible ?
Posted by: pspad | Date: 2019-01-15 14:11 | IP: IP Logged
Gabriel_ACE:
no
No it can't to know it.
File/folder path can contain spaces, URL like protocols not. So PSpad isn't able to take general text and duess where is end.
example:
I have some folder like e:\some folder name\and some other path in my disk and I want to highlight this folder.
Where is the folder path end?
#5 Re: Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-01-15 19:52 | IP: IP Logged
Anyway I am applying the option in the contextul menu Open Selected file with the default Application. Goes Wonderful !!!!!!!!!!!!!!!!
Is for a simple txt file i am using for year to write down my works.
Each work has a windows folder assigned.
Now I can go !!!!!!!!
I put by example :
436.18 Comprobación substitucion piezas por otras sin autori
Y:\GABINETE\PROYECTOS\436.18
I selected with the mouse the text Y:\GABINETE\PROYECTOS\436.18 and launch with the right click option of the mouse.
You can use too for programs, files, urls.....
Let me see with a .lnk file... :
No. I suppose because a lnk file there is not exist a default application to open it.
And a folder with spaces in the path ... :
Y:\DATOS PARA EL RECUERDO\coreldrw\curriculum y busqueda trabajo
Wonderfully opened !!!!!!!!
smiling smiley
Can I launch PsPad from inside Pspad ?¿?¿?¿?¿?¿?¿
let me see
Y:\PORTABLES\DESARROLLO\PSPad\PSPad.exe
Eureka !!!!!!! It's working like a charm !!!!!!!!
I can launch video or audio files too
I have a script a long time ago to select a line of text. I am using the Control+. for this purpose
Can I have a script to select a text and remain selected to be launched ?
It was easy . I don't remember the environment : AHK, Autoit, phrase express.....
Can I with Pspad write a script for these and assign a hotkey ?
Nice program indeed
#6 Re: Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-01-15 22:56 | IP: IP Logged
Can I do a script to select from the cursor to the beginning of the line and then select the option in the contextual menu Open Selected file with the default application ?
It's very interesting !!!!!
smiling smiley
Nice program indeed
#7 Re: Link to a folder in a txt file is possible ?
Posted by: Gabriel_ACE | Date: 2019-01-18 12:08 | IP: IP Logged
Esgrimidor:
smiling smiley
eso que dijiste si se puede master! (ya me di cuenta que hablas españo como yo jajajaj)
#8 Re: Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-02-01 00:11 | IP: IP Logged
Gabriel_ACE:
Esgrimidor:
smiling smiley
Can you do that script ? (puedes hacer ese programa ? )
Nice program indeed
#9 Re: Link to a folder in a txt file is possible ?
Posted by: Gabriel_ACE | Date: 2019-02-01 19:42 | IP: IP Logged
disculpa, no tengo los conocimientos de javascript nesesarios para eso
si no con gusto te ayudaba
#10 Re: Link to a folder in a txt file is possible ?
Posted by: Esgrimidor | Date: 2019-02-04 13:26 | IP: IP Logged
Ejem. I know is possible too. Now to wait someone that can help with the corresponding script.
smiling smiley
Nice program indeed
